Hi forum, it's me again.
This time I have a question about an analysis including large plastic deformations.
I try to simulate a plastic tube, that has several folds in it. (I included a picture for your better understanding). One side of the tube is constrained, the other side is closed with a stiff cap.
Now I define an increasing inner pressure, in other words I inflate the tube.
What I wanna see is, that while the tube inflates and expands, the folds flatten more and more until the tube is almost plain, somewhere at this point the material model should fail and there should be divergence.
The point of failure should be somewhere between 4 and 5 bar in reality, ANSYS and Abaqus which I both used for validating my Code_Aster-results do tell me something like that.
But the strange thing is, that CA reaches almost 8 bar before diverging.
The obvious reason is, that my model behaves much to stiff in C_A, the folds do not flatten in the same manner they do in ANSYS/Abaqus. Hence I do get the biggest plastic strains at the wrong place in my model. So I varieed the element types, and now here we go with the story:
Originally, my model consists of linear quad4 shell elements. But if I understood right what I read in the documetation and this forum, these elements are supposed to be plain, so I can't use them.
Furthermore „Simo_Miehe“, what I wanted to use, is not implemented for them.
I then used linear hex8-elements with Simo-Miehe. That is the case I mentioned above: It converges, but behaves to stiff. Because of that, I wanted to use reduced integrated elements (3D_SI) because of their reduced stiffness, but then CA tells me, that Simo-Miehe is not implemented for them as well.
Okay, lets try quadratic hex20. They seem to behave better, but still they don't represent the flattening of the folds and diverge way to late. Besides, the computational time is painfully long with them. I know, that the discretisation with quadratic elements may be much coarser, but my geometry demands a relatively fine meshing.
So right now, I changed to quadratic shells and modelisation type „coque_3D“. But the documentation and CA itself indicate me, that I then have to use deformation type „Green_GR“, which isn't correct in my eyes, since I do have large deformations.
So as a summary, my big question is:
Which combination of element type and deformation type is suited to represent my model behaviour?
I can't believe that there is no way to reach better results, I just think that I didn't get right everything by now!
Thanks in advance for your advices.
Attached you find an document with some pictures. If demanded, I can also post one of my inputs here, but since I don't get execution errors and my simulation obviously goes in the right direction, I thought it is not necessary.
Have a nice day -
BeNe
tube.pdf, 1346762kb
