Dear kvaswegen!
The answer of ACKWA solv only simple problems of unit thicknesses.
If You don't have this situations, but You have linear cases you could do following:
.......* Multiply the E-Modulus by tv/ti (tv is a Constant-Thickness to get a simple relation)
.......* You have to look to the loads to correct them!
.......* with CREA_CHAMP you could create and multiple the stresses to get the correct
answer for your needed stresses (Faktor ti/tv).
For some non-linear algorithm You could also do so by correction of the criteria in relation to the thicknesses!
