I'm trying to install CA 10.2 on slackware64 13.1: I started the installation procedure with python setup.py install using the default setup.config file.
The procedure run apparently with no errors but ended without the expected diagnostic message and the Aster_Version directory doesnt exist on my Aster_Root (/opt/aster/).
All dependencies seems to be satisfied, I only received a warning about libg2c.
In the log file I noticed this message on the Aster 10.2 installation section:
'aster' requires this file : /opt/aster/bin/as_run
'aster' requires this file : /opt/aster/etc/codeaster/profile.sh
*** Exception raised : missing objects
Problem with : /opt/aster/bin/as_run, /opt/aster/etc/codeaster/profile.sh
Any advice?
Thanks
setup.log, 1167496kb
