Thanks for your support jean pierre,
jeanpierreaubry wrote:
the curves you produce do not like odd to me (i did not check the value though)
with which tool did you made them?
however their titles look strange to me
it is better nowadays to export a.med file from gmsh, you can nme the group within gmsh
jean pierre aubry
I have used GMSH to plot them, just switch the view space from 3D to 2D space in the option of the post pro module of GMSH.
I have tried to export the mesh as MED format but as I did not name manually my groups in GMSH (I use the number generated directly from GMSH) the script crash cause it does not now the named group GM101,... and every other group that I refer to with the gmsh file format.
The other try is import as GMSH and export as MED, in this way there is only the displacement plot when I open the result rmed file with GMSH (no VY, VZ, MFY, ...). However when I print the results in a RESU file those components are calculated!
I will give a try with complete import/export as MED files to see what happen.
Regards,
Paul
PigVert.tar.gz, 12939kb
