Hi!
Thank you for all your help!!
It really help to know that my boundary conditions were right. Thus I took a look to the cohesive parameters and found the problem was there (as AsterO'dactyle said)
I was using so much steps because in the cohesive model I want to capture the elastic (linear response), and displacement control because fracture problems are not always stable under force-control.
Thanks also for the recomendation of the PILOTAGE option! In principle I wanted to check stable systems and decided not to use it. Moreover, I tried and works quite good. A bit of deviation but good enought. I wonder if the pilotage is like a "riks method" or something similar?
I post again the comm file and the mail file (I am using aster alone without salome sorry about that). The cohesive parameters are set to have stable conditions. Notice that I have changed the way in which I define the loading condition, hopefully correct.
Thank you all again, :)
Fernando
cohtest.comm, 2934kb
