what You desire is impossible because we can't see the difference of Your 2 calculations.
A supposition: LIAISON_SOLIDE and LIAISON_UNIF often are mis-understood (because not easy to understand and no visualisation). Could You verify that You do Your calculations with the same number of degrees of freedom?: Look in You .mess-file for something like:
LE NOMBRE DE DDL
TOTAL EST: 78
DE LAGRANGE EST: 36
LE NOMBRE DE DDL ACTIFS EST: 24
If You need further help it is useful that You post Your .mess
Regards Johannes Ackva
______________________________________________________________________
Ingenieurbüro für Mechanik
Dr.-Ing. Johannes Ackva
Markgrafenstr. 21
D 91717 Wassertrüdingen
next CODE-ASTER-courses
*** Code-Aster QuickStart, 8-9 of May 2012, at Gompute User meeting in Göteborg, Sweden
www.simdi.se
CODE-ASTER-courses at Ingenieurbüro für Mechanik, Germany
*** SALOME and CODE-ASTER for beginners and nearly-beginners
4 days, Wed 19 Sep- Sat 22 Sep 2012
*** DYNAMIC ANALYSIS WITH CODE-ASTER
2 days, Thursday 18 Oct- Fri 19 Okt 2012
