Concerning "Salome overview".
slides 4 to 20
in every title the should be removed:
Salome, the GEOM module => Salome, GEOM module
Salome, the SMESH module => Salome, SMESH module
slide 5
Import / export at different formats
Various import / export formats
slide 6 is in french
slide 9
Prepared at this stage the definition of topological entities relevant to the mesh and then the calculation and its postprocessing
Define at this step the relevant topological entities to ease mesh creation, calculation setup, and result post-processing.
Manage several geometric objects useful for building groups of mesh[/b] (boundary conditions, material [b]assignment)
Manage geometric objects from which can be created element / node groups required when assigning boundary conditions or material properties...
Geometric operation to define separations in a mesh
Geometric operations to define partitions in a mesh
Non hexahedral shape splitted in hexahedrons
Split non-hexahedral shape into hexahedal ones.
To assemble
It seems to me being contradictory with the title of this subpart "Geometric operation to define partitions in a mesh".
To merge
or
To unite
slide 10
The geometric model is imported from the GEOM module
The geometric model is imported from GEOM module
Informations and quality control of the meshes
Informations and quality control of meshes
Groups of mesh elements and operations on these groups
Groups of nodes or elements and operations on these groups
Import and export of meshes at various formats
The mesh calculation start from the smallest to the largest dimension:
The mesh calculation startS from the smallest to the largest dimension
slide 14
Like slide 7, I would call it: Salome, PARAVIS module: terminology
In Paravis, the data is manipulated and changed through filters
In Paravis, the data is managed by means of filters.
They can follow on.
They can be defined consecutively.
or
They can be chained.
slide15
Viewing a displacement field
Visualization of a displacement field.
Bests,
Pierre
PS: for every ten feedbacks, do I have the right to ask for a Code_Aster extension? :)
