Dear Thomas,
thank you for your help. I am back after updating my old UBUNTU version, to the 12.1 and reloading SALOME-MECA. I passed again the original problem, a cube carved by a cylinder. No probs for geometry and meshing everything ran perfectly, but still the solution phase does not go to the end. I am enclosing a transcript of the terminal messages.
Given my total inexperience I can notice that:
NO ! /home/ponipei/Programmi/SALOME-MECA-2012.1-LGPL/SALOME/Salome-V6_4_0-x86_64/prerequisites/Matplotlib_101/bin
NO ! /home/ponipei/Programmi/SALOME-MECA-2012.1-LGPL/SALOME/Salome-V6_4_0-x86_64/prerequisites/Gl2ps_135/bin
something seems to be missing to the programme (correct paths perhaps ?)
What is the OMA module ?
* Environment variable OMA_ROOT_DIR must be set
* Module OMA will be not available
Generic warnings following. Are they relevant for the correct running of the programme ?
Generic Warning: In /local01/salome/prerequisites/src/Paraview-3101p2-py266-hd184-gr2263-dox173_patch-xml2278-qt463p1-cm285/VTK/Common/vtkObjectFactory.cxx, line 272
Old Style Factory not loaded. Shared object has vtkLoad, but is missing vtkGetFactoryCompilerUsed and vtkGetFactoryVersion. Recompile factory: /home/ponipei/Programmi/SALOME-MECA-2012.1-LGPL/SALOME/Salome-V6_4_0-x86_64/prerequisites/../modules/PARAVIS_V6_4_0/lib/paraview/libTableReaderPlugin.so, and use VTK_FACTORY_INTERFACE_IMPLEMENT macro.
Old Style Factory not loaded. Shared object has vtkLoad, but is missing vtkGetFactoryCompilerUsed and vtkGetFactoryVersion. Recompile factory: /home/ponipei/Programmi/SALOME-MECA-2012.1-LGPL/SALOME/Salome-V6_4_0-x86_64/prerequisites/../modules/PARAVIS_V6_4_0/lib/paraview/libNavigationMode.so, and use VTK_FACTORY_INTERFACE_IMPLEMENT macro.
Old Style Factory not loaded. Shared object has vtkLoad, but is missing vtkGetFactoryCompilerUsed and vtkGetFactoryVersion. Recompile factory: /home/ponipei/Programmi/SALOME-MECA-2012.1-LGPL/SALOME/Salome-V6_4_0-x86_64/prerequisites/../modules/PARAVIS_V6_4_0/lib/paraview/libMedReaderPlugin.so, and use VTK_FACTORY_INTERFACE_IMPLEMENT macro.
Old Style Factory not loaded. Shared object has vtkLoad, but is missing vtkGetFactoryCompilerUsed and vtkGetFactoryVersion. Recompile factory: /home/ponipei/Programmi/SALOME-MECA-2012.1-LGPL/SALOME/Salome-V6_4_0-x86_64/prerequisites/../modules/PARAVIS_V6_4_0/lib/paraview/libElevationSurface.so, and use VTK_FACTORY_INTERFACE_IMPLEMENT macro.
Old Style Factory not loaded. Shared object has vtkLoad, but is missing vtkGetFactoryCompilerUsed and vtkGetFactoryVersion. Recompile factory: /home/ponipei/Programmi/SALOME-MECA-2012.1-LGPL/SALOME/Salome-V6_4_0-x86_64/prerequisites/../modules/PARAVIS_V6_4_0/lib/paraview/libELNOFilter.so, and use VTK_FACTORY_INTERFACE_IMPLEMENT macro.
Old Style Factory not loaded. Shared object has vtkLoad, but is missing vtkGetFactoryCompilerUsed and vtkGetFactoryVersion. Recompile factory: /home/ponipei/Programmi/SALOME-MECA-2012.1-LGPL/SALOME/Salome-V6_4_0-x86_64/prerequisites/../modules/PARAVIS_V6_4_0/lib/paraview/libScaleVector.so, and use VTK_FACTORY_INTERFACE_IMPLEMENT macro.
Old Style Factory not loaded. Shared object has vtkLoad, but is missing vtkGetFactoryCompilerUsed and vtkGetFactoryVersion. Recompile factory: /home/ponipei/Programmi/SALOME-MECA-2012.1-LGPL/SALOME/Salome-V6_4_0-x86_64/prerequisites/../modules/PARAVIS_V6_4_0/lib/paraview/libParaMEDCorbaPlugin.so, and use VTK_FACTORY_INTERFACE_IMPLEMENT macro.
file init.py not found ???
/home/ponipei/Programmi/SALOME-MECA-2012.1-LGPL/appli/lib/python2.6/site-packages/salome/import_hook.py: ImportWarning: Not importing directory 'aster': missing __init__.py
module= original_import(name, globals, locals, fromlist, *args, **kwds)
/home/ponipei/Programmi/SALOME-MECA-2012.1-LGPL/appli/lib/python2.6/site-packages/salome/import_hook.py: ImportWarning: Not importing directory '/home/ponipei/Programmi/SALOME-MECA-2012.1-LGPL/aster': missing __init__.py
dans Aster
exporting files ???
16 INFO prepare execution for ponipei@ubuntu
16 INFO copy export files...
16 INFO create directory /tmp/ponipei-localhost-0001-3304-ubuntu...
16 INFO done
16 INFO copy /tmp/astk_ponipei/0001-3304-ubuntu.export to /tmp/ponipei-localhost-0001-3304-ubuntu
16 INFO returns 0
16 INFO copy /tmp/astk_ponipei/0001-3304-ubuntu.orig.export to /tmp/ponipei-localhost-0001-3304-ubuntu
16 INFO returns 0
16 INFO copy data files...
16 INFO no file to copy.
16 INFO execute on ponipei@ubu
final abort message
16 INFO returns 0
16 INFO job status is ENDED
16 INFO get result files from the server
16 INFO copy /home/ponipei/flasheur/linear-static.p0001-3304-ubuntu to /tmp/astk_ponipei/flasheur_ubuntu/linear-static.p0001-3304-ubuntu
16 INFO returns 0
16 INFO copy /tmp/ponipei-localhost-0001-3304-ubuntu/0001-3304-ubuntu.orig.export to /tmp/astk_ponipei/0001-3304-ubuntu.orig.export
16 INFO returns 256
16 WARNING the results seem already downloaded.
th. 139708060596096 - Trace /local01/salome/V6_4_0/modules/src/VISU_V6_4_0/src/VISU_I/VISUConfig.cc [525] : GetServant - Unknown exception was occured!!!
Thanks again for your kind help.
Bruno Picasso
cubo_.odt, 27010kb
