Compiler variables for mumps (set as environment variables):
export CC='/usr/bin/gcc'
export CFLAGS='-O2 -fno-stack-protector -fPIC'
export CFLAGS_DBG='-g -fno-stack-protector -fPIC'
export CFLAGS_OPENMP='-fopenmp'
export CXX='/usr/bin/g++'
export CXXLIB='-L/usr/lib64/gcc/x86_64-suse-linux/4.7 -lstdc++'
export DEFINED='LINUX64 _USE_OPENMP'
export F77='/usr/bin/gfortran'
export F90='/usr/bin/gfortran'
export F90FLAGS='-O2 -ffixed-line-length-0 -x f77-cpp-input -fPIC'
export F90FLAGS_DBG='-g -ffixed-line-length-0 -x f77-cpp-input -fPIC'
export F90FLAGS_I8=' -fdefault-double-8 -fdefault-integer-8 -fdefault-real-8'
export F90FLAGS_OPENMP=' -fopenmp'
export FFLAGS='-O2 -fPIC'
export FFLAGS_DBG='-g -fPIC'
export FFLAGS_I8=' -fdefault-double-8 -fdefault-integer-8 -fdefault-real-8'
export FFLAGS_OPENMP=' -fopenmp'
export LD='/usr/bin/gfortran'
export LDFLAGS_OPENMP=' -fopenmp'
export MATHLIB='/usr/lib64/liblapack.a /usr/lib64/libblas.a'
export OTHERLIB='-L/usr/lib64 -lpthread'
# Environment settings :
Checking for dependencies and required variables for 'mumps'... [ OK ]
Checking for libesmumps.a... no
Checking for libesmumps.so... no
Traceback (most recent call last):
File "setup.py", line 938, in <module>
main()
File "setup.py", line 904, in main
'reinstall' : opts.reinstall,
File "/opt/aster113/aster-full-src-11.3.0/products.py", line 920, in setup_mumps
err=True, append=True)
File "/opt/aster113/aster-full-src-11.3.0/as_setup.py", line 1915, in findlib_and_set
silent, prefix_to, reqpkg)
File "/opt/aster113/aster-full-src-11.3.0/as_setup.py", line 1854, in find_and_set
raise SetupConfigureError(msg)
SetupConfigureError:
Unable to find libesmumps.a or libesmumps.so
