Dear Vincent,
thanks for the reply. That got me thinking that I plugged engineering stress vs. eng. strain into the material model instead of true stress vs. true strain. Is there a general rule of thumb up to which degree of deformation and which behaviour models one may still use with eng. strain? Problem is that mostly true strain data is not available. I will try to get those values for my material anyway. Should just be a question of time.
Until then, I used your suggestion of D_SIGM_EPSI=0.2 * E. This postpones my divergence problem to a later stage. I reach about 9.9 MPa. Since this is still far away from rule of thumb burst pressure I fear there is a different problem still - not only material curves.
What really bugs me is that I am not only not converging (i.e. algorithm parameters), but really diverging quickly:
Instant de calcul: 7.423443603977e-01
| NEWTON | RESIDU | RESIDU | OPTION |
| ITERATION | RELATIF | ABSOLU | ASSEMBLAGE |
| | RESI_GLOB_RELA | RESI_GLOB_MAXI | |
| 0 X | 2.42741E-06 X | 3.18654E-01 |TANGENTE |
| 1 X | 2.42753E-06 X | 3.18672E-01 | |
| 2 X | 6.31498E-06 X | 8.28983E-01 | |
| 3 X | 6.32372E-06 X | 8.30142E-01 | |
| 4 X | 2.03235E-05 X | 2.66787E+00 | |
| 5 X | 2.08268E-05 X | 2.73406E+00 | |
| 6 X | 6.56080E-05 X | 8.61184E+00 | |
| 7 X | 6.91393E-05 X | 9.07677E+00 | |
| 8 X | 2.11829E-04 X | 2.77997E+01 | |
| 9 X | 2.24357E-04 X | 2.94585E+01 | |
| 10 X | 6.83919E-04 X | 8.96986E+01 | |
| 11 X | 7.15681E-04 X | 9.40158E+01 | |
| 12 X | 2.21045E-03 X | 2.89320E+02 | |
| 13 X | 2.20491E-03 X | 2.90104E+02 | |
| 14 X | 7.20656E-03 X | 9.36989E+02 | |
| 15 X | 7.07785E-03 X | 9.36037E+02 | |
| 16 X | 2.53971E-02 X | 3.22353E+03 | |
| 17 X | 5.23005E-02 X | 7.04359E+03 | |
| 18 X | 2.14799E-01 X | 2.24818E+04 | |
| 19 X | 2.35662E+00 X | 3.72966E+05 | |
| 20 X | 1.84583E+01 X | 1.47495E+08 | |
| 21 X | 1.45109E+01 X | 7.81110E+11 | |
| 22 X | 1.40113E+01 X | 4.17713E+15 | |
| 23 X | 1.40010E+01 X | 2.25469E+19 | |
| 24 E | 1.40071E+01 X | 1.21878E+23 | |
COMM and MESS with changed D_SIGM_EPSI attached.
Any other hints?
Best regards,
Katrin
PS: How do I "professionally" include code pieces into the posts?
burstpress_2nd.zip, 90991kb
