Hi all,
I try to model a square profile rotating within another square with simple contact so far. However I just don't get how to set up the model with appropriate BCs. (squarerotation.jpg)
Any advice? What I did so far to apply the rotation:
Set up additional point at coordinate base named: TORQUE, apply DRZ 0,1 to point, link point to inner mesh with LIAISON_SOLIDE.
Problems:
1) No symmetry between the edges marked in yellow, thus wrong. (compare 2nd picture)
2) Missing deformation of inner square because of LIAISON_SOLIDE, thus not really useful.
Ideas:
1) Use LIAISON_GROUP to set up cyclic symmetry
2) LIAISON_SOLIDE ONLY to the edges with cyclic symmetry
Result:
1) Following error:
! <EXCEPTION> <MODELISA8_77> !
! Il y a un conflit dans les vis-à-vis des noeuds. Le noeud N12 est !
! à la fois le vis-à-vis du noeud N38 et du noeud N5. !
! Conseils : !
! - Si la distance entre les deux surfaces à apparier est grande devant leurs dimensions, précisez l'isométrie qui permet de les !
! superposer par l'intermédiaire des mots-clés CENTRE, ANGL_NAUT et TRAN. !
! - Si les maillages sont incompatibles, utilisez plutôt le chargement LIAISON_MAIL. !
Meshes should be compatible since it es 11 nodes on each edge distributed via wire_dicretization and local length, shouldn't it?
2) did not get so far because of 1)
Any ideas, help suggestions are appreciated.
Regards,
highpressuretube
Set-Up-SquareRotation.jpg, 46372kb
