I included your plugins via binding, but this does not work:
singularity run --app install -B /home/mario/.config/salome/Plugins salome_meca-lgpl-2024.1.0-1-20240327-scibian-11.sif
The binding is not done.
But when I:
"singularity run --nv -B /home/mario/.config/salome/Plugins salome_meca-lgpl-2024.1.0-1-20240327-scibian-11.sif"
the binding works, but Asterstudy doesn't.
So I'll switch between the two, I won't need the plugins often I think.
I also tried installing Salome 9.15 standalone, but this is, excuse my language, a complete mess.
However, in your video you also show a plugin named "Internal Contour". This does not seem to be included on the GitHub. Is it missing?
Thanks, Mario.
EDIT: when I use Salome such that the Plugins work, I save the file. Next time I open it, it takes forever to load, the file seems to be garbage.
