I was about to start a new topic, but as this is relatively new and is quite similar to mine problem I decided to post here instead.
Well, I'm trying to use SHB elements to see if I can model as solid some things but obtaining the Moments, normal and shear forces. Therefore, I set a simple beam problem but if I add the lines to calculate SIEF (or EFGE) data it doesn't export anything and the information of the file in Paravis shows a NA in the data (see attached figure)
So now I have 2 questions:
1) How can I make that my project calculates the SIEF or EFGE values to be visualized in Paravis (my current COMM and mesh are in the attached file)
2) How can I visualize the bending moments, and forces from the SIEF data?
thx for any hint
Archive.zip, 435486kb
