So I have a CAD file I have exported from another program as an IGES file, the models measurements are in mm.
Using the geometry module of Salome-Meca I import the IGES file and get the following message:
"Take into account (millimetre) embedded to the file?
Ignoring units will cause model scaling (as dimensions are supposed to be specified in meters)."
So I click "Yes" on this message.
Does this mean for all other values I need to use the metres form or the millimetres?
For example when in the AsterStudy module should I specify my youngs modulus in N/m^2 or N/mm^2?
Thank you.
