Hi everyone !
I'm using code aster with Salome Meca. I need to check the values of a heat source that I defined with "Sour_NL" and "DEFI_Fonction". My idea is to use "POST_RELEVE_T" to extract "sour_elga" but salome didn't find any "GROUP_NO" while I try to define the parameters of "POST_RELEVE_T", althouh I create a group of node with "DEFI_GROUP" named --> CU_NO. Did someone know why salome didn't link CU_NO in "POST_RELEVE_T" ?
If someone knows a better way to extract the values of the heat source, I'm interested too !
Thanks in advance for your answer,
Ludovic
DEBUT(LANG='EN')
mesh18 = LIRE_MAILLAGE(identifier=u'0',
UNITE=20)
mesh18 = DEFI_GROUP(identifier=u'1',
reuse=mesh18,
CREA_GROUP_MA=_F(GROUP_MA=('CU', ),
NOM='CU_MA'),
CREA_GROUP_NO=_F(GROUP_NO=('CU', ),
NOM='CU_NO'),
MAILLAGE=mesh18)
model = AFFE_MODELE(identifier=u'2',
AFFE=_F(MODELISATION=('PLAN', ),
PHENOMENE='THERMIQUE',
MAILLAGE=mesh18)
listr = DEFI_LIST_REEL(identifier=u'3',
DEBUT=0.0,
INTERVALLE=_F(JUSQU_A=1000.0,
PAS=10.0))
P_joule = DEFI_FONCTION(identifier=u'4',
ABSCISSE=(-20.0, -19.8090040928, -19.6180081855, -19.4270122783, -19.2360163711, -19.0450204638, -18.8540245566, -18.6630286494, -18.4720327422, -18.2810368349, -18.0900409277, -17.8990450205, -17.7080491132, -17.517053206, -17.3260572988, -17.1350613915, -16.9440654843, -16.7530695771, -16.5620736698, -16.3710777626, -16.1800818554, -15.9890859482, -15.7980900409, -15.6070941337, -15.4160982265, -15.2251023192, -15.0341064...
NOM_PARA='TEMP',
NOM_RESU='P',
ORDONNEE=(196925.594186, 197104.698865, 197283.803544, 197462.908222, 197642.012901, 197821.11758, 198000.222258, 198179.326937, 198358.431616, 198537.536294, 198716.640973, 198895.745652, 199074.85033, 199253.955009, 199433.059688, 199612.164366, 199791.269045, 199970.373724, 200149.478402, 200328.583081, 200507.68776, 200686.792438, 200865.897117, 201045.001796, 201224.106474, 201403.211153, 201582.315832, 201761.42051, 201...
CU = DEFI_MATERIAU(identifier=u'14',
THER_NL=_F(LAMBDA=Condu_CU,
RHO_CP=rho_Cp))
load = AFFE_CHAR_THER_F(identifier=u'23',
SOUR_NL=_F(GROUP_MA=('CU', ),
SOUR=P_joule))
load0 = AFFE_CHAR_THER(identifier=u'24',
ECHANGE=_F(COEF_H=50.0,
GROUP_MA=('R_Outer_Sheath_HDPE', ),
TEMP_EXT=30.0),
resther = THER_NON_LINE(identifier=u'26',
CHAM_MATER=fieldmat,
ETAT_INIT=_F(VALE=30.0),
EXCIT=(_F(CHARGE=load0),
_F(CHARGE=load)),
INCREMENT=_F(LIST_INST=listr),
resther = CALC_CHAMP(identifier=u'27',
reuse=resther,
RESULTAT=resther,
THERMIQUE=('FLUX_NOEU', 'SOUR_ELGA'))
table = MACR_LIGN_COUPE(identifier=u'28',
LIGN_COUPE=_F(COOR_EXTR=(0.0417852, -0.0283592),
COOR_ORIG=(0.0157925, -0.0091955),
NB_POINTS=50,
TYPE='SEGMENT'),
NOM_CHAM='TEMP',
RESULTAT=resther,
UNITE_MAILLAGE=2)
IMPR_RESU(identifier=u'30',
RESU=_F(RESULTAT=resther),
UNITE=80)
IMPR_TABLE(identifier=u'31',
FORMAT='XMGRACE',
NOM_PARA=('ABSC_CURV', 'TEMP'),
TABLE=table,
UNITE=10)
IMPR_FONCTION(identifier=u'32',
COURBE=_F(FONCTION=P_joule),
FORMAT='XMGRACE',
UNITE=29)
IMPR_TABLE(identifier=u'33',
FORMAT='TABLEAU',
TABLE=table,
UNITE=8)
