hello,
the message means that a GROUP of master elements (GROUP_MA_MAIT*) must contain volume elements if the model is 3D
(respectively must contain 2D elements if the model is 2D)
With other words: a master group must contain elements of the same dimension as the model is.
This behaviour is the same in LIAISON_CYCL and LIAISON_MAIL.
So you do not glue (nodes of) face to a face but (nodes of) face to a volume, this might surprise but is fully correct.
An example is test case sdll133b
A discussion about you find also here:
https: //code-aster.org/forum2/viewtopic.php?id=19761
even due to the lenght it might be confusing, look to the first contribution of Richard
Regards
Johannes_ACKVA
*** NEW: all Code-Aster courses now as Video and Webinar courses ***
