Hi
Is there anyone out there who has moved to Code-Aster from CalculiX?
If yes, then could you tell me why?
Actually, I am trying to move from ABAQUS to an open-source tool, and I chose to work on CalculiX last year when I started this transition. I remember vaguely trying to search for the differences b/w CalculiX and Code-Aster back then also but could not find anything significant. Anyway, I think I chose CalculiX probably because I found it easier to set up. Basically, I just want to be sure that I am not missing out on available features if I choose to work with one of them (currently it is CalculiX as I mentioned earlier).
It would be nice to have some suggestions/comments on which one is better (CalculiX or Code-Aster). Maybe both have their advantages and disadvantages. Maybe it depends upon the type of problems at hand (2D/3D, Mechanical/Thermal/Coupled, etc.).
The type of problem that I am looking to solve is a high-speed impact/blast/shock wave type loading on a soft foam/rubber-like material.
To start off the discussion, let me post the things that I've noticed so far:
1. CalculiX community seems to be a smaller one (judging from the no. of users/active discussion forums that I could find: one is on Discord, a server by the name of Elmer, and another on Discourse named as calculix.discourse.group). I am guessing that the CA forum (this one) has more users which is better
2. Code-Aster documentation seems to be more comprehensive or I should say organized (at least that is what I gather).
3. Another difference is the choice of programming language. CalculiX I know uses primarily FORTRAN and C and Code-Aster works on Python I guess.
Comments are welcome.
Maybe, you can add to the list of differences you've noticed/found between the two open-source FEA codes.
Thanks
