>>> Extraction <<<
entering directory '/tmp/install_tfel.343143'
Extracting tfel-3.2.1-1.tar.gz... [ OK ]
--- 7044 files extracted
leaving directory '/tmp/install_tfel.343143'
>>> Configuration <<<
entering directory '/tmp/install_tfel.343143/tfel-3.2.1'
Command line : mkdir build ; cd build ; cmake .. -DCMAKE_BUILD_TYPE=Release -DTFEL_SVN_REVISION=3.2.1 -DTFEL_APPEND_VERSION=3.2.1 -DCMAKE_Fortran_COMPILER=/usr/bin/gfortran -Dlocal-castem-header=ON -Denable-fortran=OFF -Denable-broken-boost-python-module-visibility-handling=ON -Denable-python-bindings=ON -Denable-cyrano=ON -Denable-aster=ON -Ddisable-reference-doc=ON -Ddisable-website=ON -Denable-portable-build=OFF -DPython_ADDITIONAL_VERSIONS=3.8 -Denable-python=ON -DPYTHON_EXECUTABLE=/usr/bin/python3 -DPYTHON_LIBRARY=/usr/lib/python3.8/config-3.8-x86_64-linux-gnu/libpython3.8.so -DPYTHON_INCLUDE_DIR=/usr/include/python3.8 -DCMAKE_INSTALL_PREFIX=/home/xiangyanggang/Software/code-aster-obj/public/tfel-3.2.1
configure tfel installation...
Command output :
configure tfel installation... [FAILED]
Exit code : 1
CMake Warning (dev) in CMakeLists.txt:
No project() command is present. The top-level CMakeLists.txt file must
contain a literal, direct call to the project() command. Add a line of
code such as
project(ProjectName)
near the top of the file, but after cmake_minimum_required().
CMake is pretending there is a "project(Project)" command on the first
line.
This warning is for project developers. Use -Wno-dev to suppress it.
Checking for dependencies and required variables for 'aster'... [ OK ]
Installation of : aster 14.6.0
Code_Aster finite element method solver.
Archive filename : aster-14.6.0
Destination : /home/xiangyanggang/Software/code-aster-obj
Working directory : /tmp/install_aster.343143
Filling cache...
'LIBPATH_MFRONT' not yet defined
'LIBPATH_SCOTCH' not yet defined
[FAILED]
Exit code : 255
*** Exception raised : unavailable variables
Problem with : LIBPATH_MFRONT, LIBPATH_SCOTCH
SUMMARY OF INSTALLATION
Installation of : hdf5 1.10.3
Destination : /home/xiangyanggang/Software/code-aster-obj/public/hdf5-1.10.3
Elapsed time : 111.39 s
[ OK ]
Installation of : med 4.0.0
Destination : /home/xiangyanggang/Software/code-aster-obj/public/med-4.0.0
Elapsed time : 119.47 s
[ OK ]
Installation of : astk 2020.0
Destination : /home/xiangyanggang/Software/code-aster-obj/lib/python3.8/site-packages
Elapsed time : 1.93 s
[ OK ]
Installation of : metis 5.1.0
Destination : /home/xiangyanggang/Software/code-aster-obj/public/metis-5.1.0
Elapsed time : 193.49 s
[ OK ]
Installation of : tfel 3.2.1
Destination : /home/xiangyanggang/Software/code-aster-obj/public/tfel-3.2.1
Elapsed time : 9.51 s
*** Exception None raised : None
See detailed traceback in the logfile
[FAILED]
Exit code : 4
Installation of : mumps 5.1.2
Destination : /home/xiangyanggang/Software/code-aster-obj/public/mumps-5.1.2
Elapsed time : 124.36 s
[ OK ]
Installation of : homard 11.12
Destination : /home/xiangyanggang/Software/code-aster-obj/public/homard-11.12
Elapsed time : 22.45 s
[ OK ]
Elapsed time : 0.01 s
[ SKIP ]
Installation of : Code_Aster + 8 of its prerequisites
Elapsed time : 594.07 s
[ OK ]
