Hello Mario,
thank you very much for your help.
After so many mistakes, it feels like magic when this simulation runs. :)
I'll take a closer look to the topic REAC_GEOM with the value NB_ITER_GEOM and the other contact parameters you set.
Of course I´ll use a 2nd order mesh for the right simulation, the 1st order mesh is only to find out how
this contact simulation works and to save computing time.
I understand what you want to tell me about the vibrations/oscillations of the parts.
It needs the springs to compensate this behavior like a damper. I´ll have a look for an informative test case for this topic.
I also tried out of interest to perform the simulation with several time steps (70 timesteps), the simulation was also well
done but ended unfortunately with "EXECUTION_CODE_ASTER_EXIT_2685=0" as you can see in the message file.
I have an error in NOM_CHAM SIEF_NOEU instead of SIEQ_NOEU but with 7 time steps this simulation ended successfully and that cannot be the reason.
It may have something to do with this error message:
Criterion of destruction of the file (1.00%) associated with the base VOLATILE exceeded 10.00%
Nombre of records used: 6289
But I can't figure it out.
Best regards
Stefan
70_timesteps_code_2685=0.txt, 1213040kb
