Same problem here.
Manjaro 23.0.0
Nvidia container installed.
Tried all the here mentioned solutions without success.
It seems a bit odd to me that when GLIBC is updated to a newer version the program is broken.
But I'm no Linux specialist.
/usr/bin/nvidia-smi
INFO : Running salome_meca in GPU mode
runSalome running on roger-hpzbook17
Searching for a free port for naming service: 2811 - OK
Searching Naming Service + found in 0.1 seconds
Searching /Kernel/Session in Naming Service +++SALOME_Session_Server: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.34' not found (required by /.singularity.d/libs/libGLX.so.0)
Traceback (most recent call last):
File "/opt/salome_meca/V2022.1.0_scibian_univ/modules/KERNEL_V9_8_0/bin/salome/orbmodule.py", line 181, in waitNSPID
os.kill(thePID,0)
ProcessLookupError: [Errno 3] No such process
During handling of the above exception, another exception occurred:
File "/opt/salome_meca/appli_V2022.1.0_scibian_univ/bin/salome/runSalome.py", line 694, in useSalome
clt = startSalome(args, modules_list, modules_root_dir)
File "/opt/salome_meca/appli_V2022.1.0_scibian_univ/bin/salome/runSalome.py", line 639, in startSalome
session=clt.waitNSPID("/Kernel/Session",mySessionServ.PID,SALOME.Session)
File "/opt/salome_meca/V2022.1.0_scibian_univ/modules/KERNEL_V9_8_0/bin/salome/orbmodule.py", line 183, in waitNSPID
raise RuntimeError("Process %d for %s not found" % (thePID,theName))
RuntimeError: Process 5970 for /Kernel/Session not found
Thanks in advance,
Roger
