BrunoZilli
Hello, I'm struggling with the same error:
Singularity> as_run 00-thermal.export
/opt/salome_meca/2023.1.0_scibian_univ/tools/Code_aster_frontend-202310/lib/python3.7/site-packages/asrun/system.py:93: DeprecationWarning: invalid escape sequence \+
mat = re.search('^([-a-zA-Z_0-9@\+]+)=(.*$)', line)
/opt/salome_meca/2023.1.0_scibian_univ/tools/Code_aster_frontend-202310/lib/python3.7/site-packages/asrun/system.py:611: DeprecationWarning: invalid escape sequence \.
name = re.sub('\.gz$', '', src)
/opt/salome_meca/2023.1.0_scibian_univ/tools/Code_aster_frontend-202310/lib/python3.7/site-packages/asrun/system.py:856: DeprecationWarning: invalid escape sequence \s
exp = re.compile('^processor\s+:\s+([0-9]+)', re.MULTILINE)
pas d'acccès en écriture dans /local00/tmp/astk_etienne
In this post post the solution is to bind the local00 directory to something on your filesystem:
singularity run --bind /tmp:/local00/tmp salome_meca-lgpl-2023.1.0-4-20240327-scibian-10-vanilla.sif shell
as_run started the calculation with a bit of gibberish at the beginning, but it seems to run
/opt/salome_meca/2023.1.0_scibian_univ/tools/Code_aster_frontend-202310/lib/python3.7/site-packages/asrun/build.py:1430: DeprecationWarning: invalid escape sequence \(
expr = re.compile('^[A-Za-z_0-9]+ *= *[OPERPROCMACROFORM]+ *\(.*',
/opt/salome_meca/2023.1.0_scibian_univ/tools/Code_aster_frontend-202310/lib/python3.7/site-packages/asrun/build.py:1553: DeprecationWarning: invalid escape sequence \.
pattern='TOTAL_JOB +: +([0-9\.]+) +: +([0-9\.]+) +: +([0-9\.]+) +: +([0-9\.]+)')
/opt/salome_meca/2023.1.0_scibian_univ/tools/Code_aster_frontend-202310/lib/python3.7/site-packages/asrun/build.py:1614: DeprecationWarning: invalid escape sequence \s
mat = re.search('^ *SUPPR +([^\s]+)', line)
/opt/salome_meca/2023.1.0_scibian_univ/tools/Code_aster_frontend-202310/lib/python3.7/site-packages/asrun/build.py:1661: DeprecationWarning: invalid escape sequence \.
mat = re.search('^ *TESSUPPR +([-_a-zA-Z0-9\.]+)', line)
/opt/salome_meca/2023.1.0_scibian_univ/tools/Code_aster_frontend-202310/lib/python3.7/site-packages/asrun/build.py:1701: DeprecationWarning: invalid escape sequence \#
linc = re.findall('^\#include *[\"\<]{1}(.*)[\"\>]{1}', code, re.MULTILINE)
/opt/salome_meca/2023.1.0_scibian_univ/tools/Code_aster_frontend-202310/lib/python3.7/site-packages/asrun/build.py:1718: DeprecationWarning: invalid escape sequence \#
mat = re.search('^\#include.*%s' % osp.basename(other), code, re.MULTILINE)
/opt/salome_meca/2023.1.0_scibian_univ/tools/Code_aster_frontend-202310/lib/python3.7/site-packages/asrun/calcul.py:579: DeprecationWarning: invalid escape sequence \.
mat = re.search('%s +([0-9\.]+) +([0-9\.]+) +([0-9\.]+) +([0-9\.]+)' % 'Total', txt)
/opt/salome_meca/2023.1.0_scibian_univ/tools/Code_aster_frontend-202310/lib/python3.7/site-packages/asrun/calcul.py:763: DeprecationWarning: invalid escape sequence \g
content = exp.sub('\g<1>%s = %s' % (para, pval), content)
/opt/salome_meca/2023.1.0_scibian_univ/tools/Code_aster_frontend-202310/lib/python3.7/site-packages/asrun/calcul.py:818: DeprecationWarning: invalid escape sequence \.
mat = re.search('JOBID *= *([0-9a-zA-Z\._\-]+)', txt)
/opt/salome_meca/2023.1.0_scibian_univ/tools/Code_aster_frontend-202310/lib/python3.7/site-packages/asrun/calcul.py:821: DeprecationWarning: invalid escape sequence \.
mat = re.search('QUEUE *= *([0-9a-zA-Z\._\-]+)', txt)
/opt/salome_meca/2023.1.0_scibian_univ/tools/Code_aster_frontend-202310/lib/python3.7/site-packages/asrun/calcul.py:825: DeprecationWarning: invalid escape sequence \.
mat = re.search('STUDYID *= *([0-9a-zA-Z\._\-]+)', txt)
/opt/salome_meca/2023.1.0_scibian_univ/tools/Code_aster_frontend-202310/lib/python3.7/site-packages/asrun/rex.py:72: DeprecationWarning: invalid escape sequence \@
exp = re.compile('\@%s\@(.*)\@FIN%s\@' % (ch, ch), re.MULTILINE | re.DOTALL)
Cheers
Etienne
