First of all, thank you very much for the suggestions that I wanted to apply to a model of a cantilever beam with dimensions of 1000x30x50 mm, discretized with hexahedral elements of 5 mm side length, and loaded on the 50x1000 face from the positive X side with a positive lateral load of 0.1 N/mm². The suggested procedure appears to work, and I am including it (complete) at the end of this comment. However, I would like to make some considerations, in case they might be of interest to someone and they may want to challenge them.
- It seems that assigning the direction of the lateral load opposite (negative) to the shape of the first mode slightly increases the value of the critical load (in reality, I can explain this, but not from the standpoint of the mathematical model). Does this imply that we must start from a buckling analysis where the model is free of imperfections?
- The values of the critical load between the condition of a perfect bar (without lateral load) and that of an imperfect bar (with lateral load to simulate imperfections) differ by only a few N, even though I have verified that the node coordinate on the upper face of the modified mesh differs from the displacement value obtained in the perfect bar model with lateral load.
- Furthermore, I expected that using a lateral load of 0.5 N/mm² compared to 0.1 N/mm² would result in a significant variation in the critical load. However, this did not occur, as the final difference is only a few N. By the way, the maximum displacement of the bar with a lateral load of 0.1 N/mm² is approximately 26 mm (almost the length of the beam's shorter side). Could it be that this condition has no effect on the critical load value?
If anyone notices any major errors in the following command list, I don’t mind if I’m criticized, as long as they point it out. Thank you.
DEBUT()
#STAGE1
mesh = LIRE_MAILLAGE(UNITE=20)
model = AFFE_MODELE(AFFE=F(MODELISATION='3D',
MAILLAGE=mesh)
mater = DEFI_MATERIAU(ELAS=F(E=210000.0,
NU=0.3))
fieldmat = AFFE_MATERIAU(AFFE=F(MATER=(mater, ),
BC = AFFE_CHAR_MECA(DDL_IMPO=F(DX=0.0,
GROUP_MA=('Fix', )),
load1 = AFFE_CHAR_MECA(FORCE_FACE=F(FX=0.5,
GROUP_MA=('Load1', )),
reslin = MECA_STATIQUE(CHAM_MATER=fieldmat,
EXCIT=(F(CHARGE=BC),
F(CHARGE=load1)),
OPTION='SIEF_ELGA')
IMPR_RESU(RESU=F(RESULTAT=reslin),
#STAGE 2
field = CREA_CHAMP(NOM_CHAM='DEPL',
NUME_ORDRE=1,
OPERATION='EXTR',
RESULTAT=reslin,
TYPE_CHAM='NOEU_DEPL_R')
mesh = MODI_MAILLAGE(reuse=mesh,
DEFORME=F(DEPL=field,
OPTION='TRAN'),
MAILLAGE=mesh)
model2 = AFFE_MODELE(AFFE=F(MODELISATION='3D',
MAILLAGE=mesh)
fieldma2 = AFFE_MATERIAU(AFFE=F(MATER=(mater, ),
MODELE=model2)
BC2 = AFFE_CHAR_MECA(DDL_IMPO=F(DX=0.0,
MODELE=model2)
Load_N = AFFE_CHAR_MECA(FORCE_NODALE=F(FZ=-1.0,
GROUP_NO=('Load3', )),
MODELE=model2)
reslin2 = MECA_STATIQUE(CHAM_MATER=fieldma2,
EXCIT=(F(CHARGE=BC2),
F(CHARGE=Load_N)),
MODELE=model2,
OPTION='SIEF_ELGA')
IMPR_RESU(RESU=F(RESULTAT=reslin2),
UNITE=80)
#STAGE3
field1 = CREA_CHAMP(NOM_CHAM='SIEF_ELGA',
NUME_ORDRE=1,
OPERATION='EXTR',
RESULTAT=reslin2,
TYPE_CHAM='ELGA_SIEF_R')
ASSEMBLAGE(CHAM_MATER=fieldma2,
CHARGE=(BC2, ),
MATR_ASSE=(_F(MATRICE=CO('K_Rigi'),
OPTION='RIGI_MECA'),
F(MATRICE=CO('G_Rigi'),
OPTION='RIGI_GEOM',
SIEF_ELGA=field1)),
MODELE=model2,
NUME_DDL=CO('dofs'))
modes = CALC_MODES(MATR_RIGI=K_Rigi,
MATR_RIGI_GEOM=G_Rigi,
OPTION='PLUS_PETITE',
TYPE_RESU='MODE_FLAMB')
IMPR_RESU(RESU=F(RESULTAT=modes),
UNITE=3)
