Traceback (most recent call last):
File "/usr/lib/python3.7/runpy.py", line 193, in _run_module_as_main
"__main__", mod_spec)
File "/usr/lib/python3.7/runpy.py", line 85, in _run_code
exec(code, run_globals)
File "/opt/venv/lib/python3.7/site-packages/mpi4py/__main__.py", line 7, in <module>
main()
File "/opt/venv/lib/python3.7/site-packages/mpi4py/run.py", line 230, in main
run_command_line(args)
File "/opt/venv/lib/python3.7/site-packages/mpi4py/run.py", line 47, in run_command_line
run_path(sys.argv[0], run_name='__main__')
File "/usr/lib/python3.7/runpy.py", line 263, in run_path
pkg_name=pkg_name, script_name=fname)
File "/usr/lib/python3.7/runpy.py", line 96, in _run_module_code
mod_name, mod_spec, pkg_name, script_name)
File "/home/ualbino/Code_Aster/Examples/SIMU_POINT/ssnv160e_cam_clay_mfront.comm", line 2, in <module>
from code_aster import AsterError
ImportError: cannot import name 'AsterError' from 'code_aster' (/home/ualbino/dev/codeaster/install/mpi/lib/aster/code_aster/__init__.py)
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
with errorcode 1.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
EXECUTION_CODE_ASTER_EXIT_5294=1
--- DIAGNOSTIC JOB : <F>_ABNORMAL_ABORT
