I noticed something, when I'm running SM2022 (which works ok) I'm getting in terminal normal info:
INFO : Running salome_meca in software rendering mode
runSalome running on W2
Searching for a free port for naming service: 2810 - OK
Searching Naming Service + found in 0.1 seconds
Searching /Kernel/Session in Naming Service ++++++++ found in 4.0 seconds
Start SALOME, elapsed time : 4.3 seconds
Warning: module HexoticPLUGIN is improperly configured!
Module HexoticPLUGIN will not be available in GUI mode!
Warning: module GHS3DPLUGIN is improperly configured!
Module GHS3DPLUGIN will not be available in GUI mode!
Warning: module GHS3DPRLPLUGIN is improperly configured!
Module GHS3DPRLPLUGIN will not be available in GUI mode!
Warning: module BLSURFPLUGIN is improperly configured!
Module BLSURFPLUGIN will not be available in GUI mode!
Warning: module NETGENPLUGIN is improperly configured!
Module NETGENPLUGIN will not be available in GUI mode!
Warning: module HYBRIDPLUGIN is improperly configured!
Module HYBRIDPLUGIN will not be available in GUI mode!
Warning: module GMSHPLUGIN is improperly configured!
Module GMSHPLUGIN will not be available in GUI mode!
When I'm running SM2023:
- running salome_meca in software rendering mode
++ using container salome_meca-lgpl-2023.1.0-4-20240327-scibian-10.sif
++ using software rendering mode (should use mesa_salome starter)
and it doesn't work.
When I'm running 2024 I'm getting the same output:
++ using container salome_meca-lgpl-2024.1.0-1-20240327-scibian-11.sif
SM 22 is looking for empty port. SM 23 and 24 not. Maybe it should? Or maybe it's blocked somehow? Could you post here what's the output on your terminal after starting SM 24?
