malo Hello, I have a problem with display on post-processing. I don't know how to solve it. You can see it on the image that I attached. Can someone help me, please ? Best regards, Malo
hberro malo Asterstudy uses a Paraview backend for visualizing results. Do you encounter these graphic issues when in Paravis ?
NorbertS Hello, you show the component 'Magnitude' which might be meaningless. Do you see this with the other components as well? Norbert
