jeanpierreaubry
Good news the simulation is runnung fine for both static and dynamic cases. Surely GREEN_LAGRANGE worked well for lage rotations.
However, I have a few questions:
Why did you create a new POI1 named n1p when a 0D element n1 already existed on the node 1. Isn't 0D element added in mesh module same as POI1 created by CREA_MAILLAGE?
Also, obs 0D element doesn't seem to do anything.
Why didn't we need to create all faces of boundary elements and assign them 3D modelisation?
I see no modelisation is applied to 'int' group of faces. Why doesn't the solver complain that no modelisation is applied to these elements. Do the 3d elements (magenta colour) 'own' their boundary 2d faces (blue faces) and automatically assign them the 3D modelisation).
This is important to know because in another hyperelastic study that I have shared , If a face group/SEG2 group is included in AFFE_CHAR_MECA, the software complaints that it needs to be assigned some modelisation(although it is sub part(boundary faces/lines) of same 3d solid elements).
I Manually replaced kk with 0 for DRZ(no stiffness) in Dynamic calculation still working fine. Also enabled gravity full from start.
DEBUT()
kk = 1.0 * 10000
mesh0 = LIRE_MAILLAGE(FORMAT='MED',
mesh = CREA_MAILLAGE(CREA_POI1=_F(GROUP_MA='n1',
NOM_GROUP_MA=('n1p', )),
INFO=1,
MAILLAGE=mesh0)
mesh = DEFI_GROUP(reuse=mesh,
CREA_GROUP_NO=(_F(GROUP_MA='n1',
NOM='n1'),
_F(GROUP_MA='obs',
NOM='obs'),
_F(GROUP_MA='int',
NOM='int')),
MAILLAGE=mesh)
model = AFFE_MODELE(AFFE=(_F(GROUP_MA='Cut_1_1',
MODELISATION='3D',
PHENOMENE='MECANIQUE'),
F(GROUP_MA=('n1p', ),
MODELISATION=('DIS_TR', ),
PHENOMENE='MECANIQUE')),
MAILLAGE=mesh)
elemprop = AFFE_CARA_ELEM(DISCRET=F(CARA='K_TR_D_N',
GROUP_MA=('n1p', ),
VALE=(10000.0, 10000.0, 10000.0, 0.0, 10000.0, 10000.0)),
mater = DEFI_MATERIAU(ELAS=_F(E=200000000000.0,
NU=0.33,
RHO=7800.0))
fieldmat = AFFE_MATERIAU(AFFE=_F(MATER=(mater, ),
listr = DEFI_LIST_REEL(DEBUT=0.0,
INTERVALLE=_F(JUSQU_A=5,
PAS=0.1))
times = DEFI_LIST_INST(DEFI_LIST=F(LIST_INST=listr),
ECHEC=F(SUBD_NIVEAU=3,
SUBD_PAS=4),
METHODE='MANUEL',
load0_m = DEFI_FONCTION(NOM_PARA='INST',
PROL_DROITE='CONSTANT',
PROL_GAUCHE='CONSTANT',
VALE=(0, 0, 1, 1))
lsolid = AFFE_CHAR_MECA(LIAISON_RBE3=_F(COEF_ESCL=1.0,
DDL_ESCL=('DX-DY-DZ', ),
DDL_MAIT=('DX', 'DY', 'DZ', 'DRX', 'DRY', 'DRZ'),
GROUP_NO_ESCL='int',
GROUP_NO_MAIT='n1'),
load = AFFE_CHAR_MECA(DDL_IMPO=_F(DRY=0.0,
DRZ=0.0,
DX=0.0,
GROUP_NO=('n1', )),
load0 = AFFE_CHAR_MECA(MODELE=model,
PESANTEUR=F(DIRECTION=(0.0, 0.0, -1.0),
GRAVITE=10.0))
try:
#comment: resnonl = STAT_NON_LINE(CARA_ELEM=elemprop,
#comment: CHAM_MATER=fieldmat,
#comment: COMPORTEMENT=(F(DEFORMATION='GREEN_LAGRANGE',
#comment: GROUP_MA='Cut_1_1'),
#comment: F(DEFORMATION='PETIT',
#comment: GROUP_MA='n1p')),
#comment: CONVERGENCE=F(ITER_GLOB_MAXI=20,
#comment: RESI_GLOB_RELA=0.001),
#comment: EXCIT=(_F(CHARGE=lsolid),
#comment: _F(CHARGE=load),
#comment: F(CHARGE=load0)),
#comment: INCREMENT=F(LIST_INST=times),
#comment: MODELE=model,
#comment: NEWTON=F(MATRICE='TANGENTE',
#comment: PREDICTION='TANGENTE',
#comment: REAC_ITER=1),
#comment: SOLVEUR=F(NPREC=-1))
resnonl2 = DYNA_NON_LINE(CARA_ELEM=elemprop,
COMPORTEMENT=_F(DEFORMATION='GREEN_LAGRANGE',
CONVERGENCE=_F(ITER_GLOB_MAXI=10,
RESI_GLOB_MAXI=1.0,
RESI_GLOB_RELA=0.01),
_F(CHARGE=load),
_F(CHARGE=load0)),
INCREMENT=_F(LIST_INST=times),
NEWTON=_F(MATRICE='TANGENTE',
REAC_INCR=1,
REAC_ITER=1),
SCHEMA_TEMPS=_F(FORMULATION='DEPLACEMENT',
SCHEMA='HHT'))
except:
pass
#comment: IMPR_RESU(FORMAT='RESULTAT',
#comment: RESU=_F(FORMAT_R='1PE12.3',
#comment: GROUP_NO=('n1', 'obs'),
#comment: NOM_CHAM='DEPL',
#comment: RESULTAT=resnonl),
#comment: UNITE=8)
IMPR_RESU(FORMAT='MED',
RESU=_F(RESULTAT=resnonl2),
UNITE=80)
Thanks and Regards
Anirudh
