Hi, my company uses Red Hat on its Linux servers. I have tried to install the scibian 11 container for salome_meca-lgpl-2024.1.0-1-20240327, but with no luck. Is this down to a compatibility problem between scibian and Red Hat? Could you suggest a different container to try that is more likely to be compatible with Red Hat? It may not be a compatibility problem, but I think this is the likely cause of the problem.
I did get the following:
WARNING: Could not find any nv files on this host!
But it's only a warning, so I guess this isn't stopping SM from starting.
I have set my DISPLAY variable.
SM appears to be running in software rendering mode, even though I didn't ask it to, but that seems OK.
Alternatively, it could be a configuration issue, although I wouldn't know how to fix that.
Thanks.
