cskn This should be an easy question to answer: Why I don't see the VMIS stresses for the rubber bonded to the inner and outer steel tubes?
vishwas Hi, Maybe stress is of the order of 1e4(lowest in color bar). Also, you really need calibrated material parameters for your rubber material (just can't input random numbers) Moreover you need ELAS_HYPER in behavior law.
cskn vishwas Thanks for your reply. I have used calibrated material numbers for C10 and C01 and behavior law is ELAS_HYPER.
jeanpierreaubry cskn plot the results selecting only the group yo want to see and adapt the scalar bar with Range mode = Custom and push Min Max button your view is in gmsh?
cskn jeanpierreaubry Thanks a lot for your suggestions, Sir. I figured it out. And thank you for your excellent book; it was one of the first references that I relied upon while learning code-aster and whenever faced with issues.
cskn vishwas Thank you for your support. I figured it out how to get the results & values that I wanted.
cskn Sound_Spinning I am not an expert; hence not sure this is the right method. After opening the .rmed file in ParaVis, applied WarpByVector and then ELGAfieldToSurface1 using Filters-Mechanics. This gave me SIEQ_ELGA_VMIS along with the animation. Similarly, for SIEQ_ELNO_VMIS too. I had to select 'Rubber' in GROUP_MA. If I select all, they are shown as two distinct groups in Properties Window and the SIEQ_ fields were not visible. Still a lot to learn!
vishwas Hi, Should be IMPR_RESU (NOM_CHAM = ('SIEQ_NOEU') , NOM_CMP = ('VMIS'), RESULTAT = RESULT, GROUP_MA =('rubber_whatever'),); Regards Anirudh Nehra
k_zurawski cskn you may also use filter Extract Group and then you'll be able to show results only for the group you extracted:
