Renaut
The indicator only tells you whether the integration point has yielded in the last increment or not. But you can still have an integration point with the indicator at 0 while the cumulated plasticity is non-zero.
Hello, if this indicator is just for visualization, you can easily apply a filter in ParaView/Paravis on the elements where the cumulated plasticity > 0.
