It works, thank you for that.
I performed some tests to understand the behaviour of POST_ELEM.
I printed the heat flow on the mesh group "2", where I apply a heat flow of 1380W/m2 (see attached stage 1 file). The area is 2.35E-2 m2 --> should lead to 32W.
when I check the integral value of FLUZ, z is the normal of my mesh elements, (see attached impr_table file), I find 129W
It is the same with my cooling circuit : i was expecting to find 1530W, but the integral value of FLUZ is 435W.
I don't understand these results. Do you see where I am wrong ?
Thank you in advance for your reply
Raphaël
