I've been trying to create stiffened plates for a class I'm teaching on aircraft structures. I'm trying to use the beam elements for the stringers and the DST elements for the skins. The end goal is to create a stiffened skin wing with ribs, spars, and stringers that I want to use for structural design.
I'm trying to enforce the constraints using LIAISON_MAIL but I've not been able to get this to work yet. I'll appreciate any help!
Here's a screenshot of the mesh :
I basically have a 2d plane and a beam running through the middle lying a constant distance from the plate (I'm modeling the beam through its centroidal axis).
Here's my stage - I'm simply interested in conducting a bending analysis :
`mesh = LIRE_MAILLAGE(UNITE=3)
model = AFFE_MODELE(AFFE=(_F(GROUP_MA=('MidLine', 'Face'),
MODELISATION='DST',
PHENOMENE='MECANIQUE'),
_F(GROUP_MA=('Beam', ),
MODELISATION='POU_D_T',
PHENOMENE='MECANIQUE')),
MAILLAGE=mesh)
elemprop = AFFE_CARA_ELEM(COQUE=F(EPAIS=0.005,
GROUP_MA=('Face', ),
VECTEUR=(0.0, 1.0, 0.0)),
POUTRE=F(CARA=('HY', 'HZ'),
SECTION='RECTANGLE',
VALE=(0.005, 0.25)))
mater = DEFI_MATERIAU(ELAS=_F(E=210000000000.0,
NU=0.3))
fieldmat = AFFE_MATERIAU(AFFE=_F(MATER=(mater, ),
load = AFFE_CHAR_MECA(DDL_IMPO=F(DRX=0.0,
DRY=0.0,
DRZ=0.0,
DX=0.0,
GROUP_MA=('bot', )),
FORCE_ARETE=F(FY=1.0,
GROUP_MA=('top', )),
LIAISON_ELEM=_F(GROUP_MA_1=('Face', ),
GROUP_MA_2=('Beam', ),
OPTION='2D_POU'),
reslin = MECA_STATIQUE(CARA_ELEM=elemprop,
CHAM_MATER=fieldmat,
EXCIT=_F(CHARGE=load),
IMPR_RESU(RESU=_F(CARA_ELEM=elemprop,
RESULTAT=reslin),
UNITE=80)
When I run it, it keeps throwing the following error :
`# Commande #0007 de /local00/tmp/run_aster_q6rt_n14/./RunCase_1_Stage_1.comm.changed.py, ligne 46
DRY=0.0,
DRZ=0.0,
DX=0.0,
GROUP_MA='bot'),
DOUBLE_LAGRANGE='OUI',
GROUP_MA='top'),
INFO=1,
LIAISON_ELEM=_F(GROUP_MA_1='Face',
GROUP_MA_2='Beam',
OPTION='2D_POU'),
VERI_AFFE='OUI',
VERI_NORM='OUI')
MAILLE : M49
MAILLE : M50
MAILLE : M51
MAILLE : M52
MAILLE : M53
MAILLE : M54
MAILLE : M55
MAILLE : M56
MAILLE : M105
MAILLE : M106
MAILLE : M107
MAILLE : M108
MAILLE : M109
MAILLE : M110
MAILLE : M111
MAILLE : M112
║ <EXCEPTION> <MODELISA6_96> ║
║ les 16 mailles imprimées ci-dessus n'appartiennent pas au modèle ║
║ et pourtant elles ont été affectées dans le mot-clé facteur : FORCE_ARETE ║
The same error was also encountered here : https://forum.code-aster.org/public/d/25467-solved-force-arete-in-a-group-ma-ca-saying-the-group-doesn-t-exist
But that relates to joining plates together, not a plate and a beam.
I'm attaching a .hdf file that can be run with salome_meca here : https://drive.google.com/file/d/1UlW8UbxlbrMj4Kx1xI0oFBN_EuUmkBiH/view?usp=sharing
