Thanks for reply. However, run_aster throws file not found error. I ran from a folder which has command file but got this error. I even removed MPI from export file. I think 17.4.0 does not have MPI support.
anirudh@anirudh-Inspiron-7591:~/Desktop/ca_mpi/crimp$ docker run --rm -it --mount type=bind,source=$(pwd),target=/home/user/data simvia/code_aster:17.4.0
user@5b3bc6fbab72:~$ cd data/
user@5b3bc6fbab72:~/data$ run_aster crimp.export
WARNING: If MPI_Abort is called during execution, result files could not be copied.
Running: mpiexec -n 4 --tag-output /opt/spack/opt/spack/linux-zen2/code-aster-17.4.0-ecm2bfgr5obydotnlte6xilvggppqnap/bin/run_aster --wrkdir /tmp/run_aster_m_qjc36b --status-file /home/user/.tmp_run_aster/run_aster_678sex61/status --no-mpi /home/user/.tmp_run_aster/run_aster_678sex61/crimp.0
[1,1]<stderr>: Traceback (most recent call last):
[1,1]<stderr>: File "<frozen runpy>", line 198, in _run_module_as_main
[1,1]<stderr>: File "<frozen runpy>", line 88, in _run_code
[1,1]<stderr>: File "/opt/spack/opt/spack/linux-zen2/code-aster-17.4.0-ecm2bfgr5obydotnlte6xilvggppqnap/lib64/aster/run_aster/run_aster_main.py", line 526, in <module>
[1,2]<stderr>: Traceback (most recent call last):
[1,2]<stderr>: File "<frozen runpy>", line 198, in _run_module_as_main
[1,2]<stderr>: File "<frozen runpy>", line 88, in _run_code
[1,2]<stderr>: File "/opt/spack/opt/spack/linux-zen2/code-aster-17.4.0-ecm2bfgr5obydotnlte6xilvggppqnap/lib64/aster/run_aster/run_aster_main.py", line 526, in <module>
[1,3]<stderr>: Traceback (most recent call last):
[1,3]<stderr>: File "<frozen runpy>", line 198, in _run_module_as_main
[1,3]<stderr>: File "<frozen runpy>", line 88, in _run_code
[1,3]<stderr>: File "/opt/spack/opt/spack/linux-zen2/code-aster-17.4.0-ecm2bfgr5obydotnlte6xilvggppqnap/lib64/aster/run_aster/run_aster_main.py", line 526, in <module>
[1,0]<stderr>: Traceback (most recent call last):
[1,0]<stderr>: File "<frozen runpy>", line 198, in _run_module_as_main
[1,0]<stderr>: File "<frozen runpy>", line 88, in run_code
[1,0]<stderr>: File "/opt/spack/opt/spack/linux-zen2/code-aster-17.4.0-ecm2bfgr5obydotnlte6xilvggppqnap/lib64/aster/run_aster/run_aster_main.py", line 526, in <module>
[1,1]<stdout>:
[1,1]<stdout>: # ------------------------------------------------------------------------------
[1,1]<stdout>: Execution of code_aster
[1,1]<stdout>:
[1,1]<stdout>: Prepare environment in /tmp/run_aster_m_qjc36b/proc.1
[1,1]<stdout>:
[1,1]<stdout>: Command file #1 / 1
[1,3]<stdout>:
[1,3]<stdout>: # ------------------------------------------------------------------------------
[1,3]<stdout>: Execution of code_aster
[1,3]<stdout>:
[1,3]<stdout>: Prepare environment in /tmp/run_aster_m_qjc36b/proc.3
[1,3]<stdout>:
[1,3]<stdout>: Command file #1 / 1
[1,0]<stdout>:
[1,0]<stdout>: # ------------------------------------------------------------------------------
[1,0]<stdout>: Execution of code_aster
[1,0]<stdout>:
[1,0]<stdout>: Prepare environment in /tmp/run_aster_m_qjc36b/proc.0
[1,0]<stdout>:
[1,0]<stdout>: Command file #1 / 1
[1,2]<stdout>:
[1,2]<stdout>: # ------------------------------------------------------------------------------
[1,2]<stdout>: Execution of code_aster
[1,2]<stdout>:
[1,2]<stdout>: Prepare environment in /tmp/run_aster_m_qjc36b/proc.2
[1,2]<stdout>:
[1,2]<stdout>: Command file #1 / 1
[1,2]<stderr>: sys.exit(main())
[1,1]<stderr>: sys.exit(main())
[1,2]<stderr>: ^^^^^^
[1,3]<stderr>: sys.exit(main())
[1,2]<stderr>: File "/opt/spack/opt/spack/linux-zen2/code-aster-17.4.0-ecm2bfgr5obydotnlte6xilvggppqnap/lib64/aster/run_aster/run_aster_main.py", line 512, in main
[1,3]<stderr>: ^^^^^^
[1,3]<stderr>: File "/opt/spack/opt/spack/linux-zen2/code-aster-17.4.0-ecm2bfgr5obydotnlte6xilvggppqnap/lib64/aster/run_aster/run_aster_main.py", line 512, in main
[1,0]<stderr>: sys.exit(main())
[1,0]<stderr>: ^^^^^^
[1,0]<stderr>: File "/opt/spack/opt/spack/linux-zen2/code-aster-17.4.0-ecm2bfgr5obydotnlte6xilvggppqnap/lib64/aster/run_aster/run_aster_main.py", line 512, in main
[1,1]<stderr>: ^^^^^^
[1,1]<stderr>: File "/opt/spack/opt/spack/linux-zen2/code-aster-17.4.0-ecm2bfgr5obydotnlte6xilvggppqnap/lib64/aster/run_aster/run_aster_main.py", line 512, in main
[1,2]<stderr>: status = calc.execute(wrkdir)
[1,2]<stderr>: ^^^^^^^^^^^^^^^^^^^^
[1,2]<stderr>: File "/opt/spack/opt/spack/linux-zen2/code-aster-17.4.0-ecm2bfgr5obydotnlte6xilvggppqnap/lib64/aster/run_aster/run.py", line 170, in execute
[1,0]<stderr>: status = calc.execute(wrkdir)
[1,1]<stderr>: status = calc.execute(wrkdir)
[1,0]<stderr>: ^^^^^^^^^^^^^^^^^^^^
[1,1]<stderr>: ^^^^^^^^^^^^^^^^^^^^
[1,1]<stderr>: File "/opt/spack/opt/spack/linux-zen2/code-aster-17.4.0-ecm2bfgr5obydotnlte6xilvggppqnap/lib64/aster/run_aster/run.py", line 170, in execute
[1,0]<stderr>: File "/opt/spack/opt/spack/linux-zen2/code-aster-17.4.0-ecm2bfgr5obydotnlte6xilvggppqnap/lib64/aster/run_aster/run.py", line 170, in execute
[1,3]<stderr>: status = calc.execute(wrkdir)
[1,3]<stderr>: ^^^^^^^^^^^^^^^^^^^^
[1,3]<stderr>: File "/opt/spack/opt/spack/linux-zen2/code-aster-17.4.0-ecm2bfgr5obydotnlte6xilvggppqnap/lib64/aster/run_aster/run.py", line 170, in execute
[1,2]<stderr>: status = self.execute()
[1,1]<stderr>: status = self._execute()
[1,2]<stderr>: File "/opt/spack/opt/spack/linux-zen2/code-aster-17.4.0-ecm2bfgr5obydotnlte6xilvggppqnap/lib64/aster/run_aster/run.py", line 186, in _execute
[1,2]<stderr>: status = self.execute_study()
[1,2]<stderr>: File "/opt/spack/opt/spack/linux-zen2/code-aster-17.4.0-ecm2bfgr5obydotnlte6xilvggppqnap/lib64/aster/run_aster/run.py", line 225, in execute_study
[1,2]<stderr>: comm = self.change_comm_file(comm)
[1,2]<stderr>: ^^^^^^^^^^^^^^^^^^^^^^^^^^^
[1,2]<stderr>: File "/opt/spack/opt/spack/linux-zen2/code-aster-17.4.0-ecm2bfgr5obydotnlte6xilvggppqnap/lib64/aster/run_aster/run.py", line 423, in change_comm_file
[1,2]<stderr>: with open(comm, "rb") as fobj:
[1,2]<stderr>: FileNotFoundError: [Errno 2] No such file or directory: '/home/anirudh/Desktop/ca_mpi/crimp/crimp_main.comm'
[1,1]<stderr>: File "/opt/spack/opt/spack/linux-zen2/code-aster-17.4.0-ecm2bfgr5obydotnlte6xilvggppqnap/lib64/aster/run_aster/run.py", line 186, in execute
[1,1]<stderr>: status = self.execute_study()
[1,1]<stderr>: File "/opt/spack/opt/spack/linux-zen2/code-aster-17.4.0-ecm2bfgr5obydotnlte6xilvggppqnap/lib64/aster/run_aster/run.py", line 225, in execute_study
[1,1]<stderr>: comm = self.change_comm_file(comm)
[1,1]<stderr>: ^^^^^^^^^^^^^^^^^^^^^^^^^^^
[1,1]<stderr>: File "/opt/spack/opt/spack/linux-zen2/code-aster-17.4.0-ecm2bfgr5obydotnlte6xilvggppqnap/lib64/aster/run_aster/run.py", line 423, in change_comm_file
[1,1]<stderr>: with open(comm, "rb") as fobj:
[1,1]<stderr>: FileNotFoundError: [Errno 2] No such file or directory: '/home/anirudh/Desktop/ca_mpi/crimp/crimp_main.comm'
[1,0]<stderr>: status = self.execute()
[1,0]<stderr>: File "/opt/spack/opt/spack/linux-zen2/code-aster-17.4.0-ecm2bfgr5obydotnlte6xilvggppqnap/lib64/aster/run_aster/run.py", line 186, in execute
[1,0]<stderr>: status = self.execute_study()
[1,0]<stderr>: File "/opt/spack/opt/spack/linux-zen2/code-aster-17.4.0-ecm2bfgr5obydotnlte6xilvggppqnap/lib64/aster/run_aster/run.py", line 225, in execute_study
[1,0]<stderr>: comm = self.change_comm_file(comm)
[1,0]<stderr>: ^^^^^^^^^^^^^^^^^^^^^^^^^^^
[1,0]<stderr>: File "/opt/spack/opt/spack/linux-zen2/code-aster-17.4.0-ecm2bfgr5obydotnlte6xilvggppqnap/lib64/aster/run_aster/run.py", line 423, in change_comm_file
[1,0]<stderr>: with open(comm, "rb") as fobj:
[1,0]<stderr>: FileNotFoundError: [Errno 2] No such file or directory: '/home/anirudh/Desktop/ca_mpi/crimp/crimp_main.comm'
[1,3]<stderr>: status = self.execute()
[1,3]<stderr>: File "/opt/spack/opt/spack/linux-zen2/code-aster-17.4.0-ecm2bfgr5obydotnlte6xilvggppqnap/lib64/aster/run_aster/run.py", line 186, in _execute
[1,3]<stderr>: status = self.execute_study()
[1,3]<stderr>: File "/opt/spack/opt/spack/linux-zen2/code-aster-17.4.0-ecm2bfgr5obydotnlte6xilvggppqnap/lib64/aster/run_aster/run.py", line 225, in execute_study
[1,3]<stderr>: comm = self.change_comm_file(comm)
[1,3]<stderr>: ^^^^^^^^^^^^^^^^^^^^^^^^^^^
[1,3]<stderr>: File "/opt/spack/opt/spack/linux-zen2/code-aster-17.4.0-ecm2bfgr5obydotnlte6xilvggppqnap/lib64/aster/run_aster/run.py", line 423, in change_comm_file
[1,3]<stderr>: with open(comm, "rb") as fobj:
[1,3]<stderr>: FileNotFoundError: [Errno 2] No such file or directory: '/home/anirudh/Desktop/ca_mpi/crimp/crimp_main.comm'
prterun detected that one or more processes exited with non-zero status,
thus causing the job to be terminated. The first process to do so was:
Process name: [prterun-5b3bc6fbab72-15@1,1]
Exit code: 1
Regards
Anirudh
