Hello thanks for the solution! I have tried with a cube of 8meter. I had some serious deformation (oh a long plate that thin 0.005m deform no kidding!). So I tried to add beams inside it on z and y.
I also added another form against the cube. (see the picture).
I tried with that code :
DEBUT(LANG='EN')
mesh = LIRE_MAILLAGE(identifier='0:1',
model = AFFE_MODELE(identifier='1:1',
AFFE=(_F(GROUP_MA=('FaceNormalY_Z', 'FaceNormal_X'),
MODELISATION='DKT',
PHENOMENE='MECANIQUE'),
_F(GROUP_MA=('renfortY', 'RenfortZ'),
MODELISATION='POU_D_T',
PHENOMENE='MECANIQUE')),
MAILLAGE=mesh)
elemprop = AFFE_CARA_ELEM(identifier='2:1',
COQUE=(_F(EPAIS=0.005,
EXCENTREMENT=-0.00025,
GROUP_MA=('FaceNormalY_Z', ),
INER_ROTA='OUI'),
F(EPAIS=0.005,
GROUP_MA=('FaceNormal_X', ),
INER_ROTA='OUI')),
ORIENTATION=(F(CARA='VECT_Y',
GROUP_MA=('renfortY', ),
VALE=(0.0, 0.0, 1.0)),
F(CARA='VECT_Y',
GROUP_MA=('RenfortZ', ),
VALE=(1.0, 0.0, 0.0))),
POUTRE=(F(CARA=('HY', 'HZ'),
SECTION='RECTANGLE',
VALE=(0.005, 0.15)),
_F(CARA=('HY', 'HZ'),
VALE=(0.005, 0.15))))
mater = DEFI_MATERIAU(identifier='3:1',
ELAS=_F(E=210000000000.0,
NU=0.3,
RHO=7850.0))
fieldmat = AFFE_MATERIAU(identifier='4:1',
AFFE=_F(GROUP_MA=('renfortY', 'RenfortZ', 'FaceNormalY_Z', 'FaceNormal_X'),
MATER=(mater, )),
MAILLAGE=mesh)
load = AFFE_CHAR_MECA(identifier='5:1',
DDL_IMPO=F(DX=0.0,
GROUP_MA=('sol', )),
PESANTEUR=F(DIRECTION=(0.0, 0.0, -1.0),
GRAVITE=9.81))
reslin = MECA_STATIQUE(identifier='6:1',
CARA_ELEM=elemprop,
CHAM_MATER=fieldmat,
#comment: reslin = CALC_CHAMP(identifier='7:1',
#comment: reuse=reslin,
#comment: CONTRAINTE=('SIEF_ELNO', ),
#comment: DEFORMATION=('EPSI_ELNO', ),
#comment: RESULTAT=reslin)
#comment: resu_sup = POST_CHAMP(identifier='8:1',
#comment: EXTR_COQUE=_F(NIVE_COUCHE='SUP',
#comment: NOM_CHAM=('SIEF_ELNO', 'EPSI_ELNO'),
#comment: NUME_COUCHE=1),
#comment: resu_sup = CALC_CHAMP(identifier='9:1',
#comment: reuse=resu_sup,
#comment: CONTRAINTE=('SIEF_NOEU', ),
#comment: DEFORMATION=('EPSI_NOEU', ),
#comment: RESULTAT=resu_sup)
#comment: IMPR_RESU(identifier='10:1',
#comment: FORMAT='MED',
#comment: RESU=(_F(NOM_CHAM=('DEPL', 'SIEF_NOEU', 'EPSI_NOEU'),
#comment: RESULTAT=resu_sup),
#comment: _F(RESULTAT=reslin)),
#comment: UNITE=80)
IMPR_RESU(identifier='11:1',
RESU=_F(MAILLAGE=mesh,
NOM_CHAM=('DEPL', ),
RESULTAT=reslin),
UNITE=3)
I also tried to use the point of the face against the ground and also just the point of its edges
I also tried with Liaison_elem or even Liaison_mail but those doesn't seem to fit what I'm doing.
With Elem it seem I have to create one for each beam... and mail doesn't seem to fit the bill too
then ended up with that error...
<EXCEPTION> <FACTOR_11> ║
║ Problème : la matrice est singulière ou presque singulière : ║
║ Lors de la factorisation de la ║
║ matrice, on a rencontré un problème ║
║ (pivot nul ou presque nul) à la ligne 601 qui correspond ║
║ au degré de liberté donné ci-dessus. ║
║ Risques et conseils : ║
║ * Si la ligne correspond a un ║
║ degré de liberté physique, il s'agit probablement d'un mouvement ║
║ de corps rigide mal ║
║ bloqué. ║
║ Vérifiez les conditions aux limites. ║
║ Si vous faites du contact, il ne faut ║
║ pas que la structure ne "tienne" que par le contact. ║
║ Vérifiez également les ║
║ caractéristiques matériaux (module d'Young, ...). ║
║ * Si la ligne correspond a un degré de ║
║ liberté de Lagrange, il s'agit sans doute d'une condition ║
║ limite redondante. ║
║ En ║
║ particulier, il se peut que la relation linéaire surabondante provienne des conditions de ║
║ contact. ║
║ Peut-être devriez vous exclure certains noeuds des conditions de contact ║
║ (mots clés SANS_NOEUD et SANS_GROUP_NO). ║
║ * Si le solveur utilisé est LDLT ou MULT_FRONT, ║
║ vous pouvez utiliser le solveur MUMPS ║
║ car celui-ci est le seul à pouvoir factoriser les ║
║ matrices qui ne sont pas définies positives. ║
║ * Parfois, en parallèle, le critère de ║
║ détection de singularité de MUMPS est trop pessimiste ! Il reste néanmoins souvent ║
║ possible de faire passer le calcul complet en relaxant ce critère (augmenter de 1 ou 2 la ║
║ valeur du mot-clé NPREC) ou ║
║ en le débranchant (valeur du mot-clé NPREC=-1) ou en ║
║ relançant le calcul sur moins de processeurs. ║
║ * Il se peut aussi que ce phénomène soit ║
║ tout à fait normal avec X-FEM si la fissure passe ║
║ très près d'un noeud. ║
║ Si le nombre ║
║ de décimales perdues n'est pas trop grand (max 10 décimales), ║
║ vous pouvez relancer le ║
║ calcul en augmentant le nombre de décimales perdues autorisé : ║
║ mot-clé NPREC du mot clé ║
║ facteur SOLVEUR. ║
║ Sinon, contactez l'équipe de développement.
And lastly I'm thinking maybe I shouldn't use beam element but just coq and turn those edge into face with the dimension I want them to have before adding their thickness in AFFE_CARA_ELEM.
