Dear All,
I am trying to make myself familiar with THM modelling. I started from WTNV121 example and modified it removing any damage model, which are known to be mesh dependent. The resulting modelling approach is RELATION_KIT=("ELAS", "LIQU_GAZ", "HYDR_UTIL").
I tried to run the same model with different mesh discretisations by splitting, but the results, for instance the water mass integrated over the volume (M11) , do not converge to a single value. Is this behaviour expected?
Thank you,
Corrado
