Dear code_aster team,
I am working on a crystal plasticity finite element (CPFE) model using the Méric-Cailletaud formulation in mfront. Having moved from code_aster 2021 to 2024, I realized that SIMO_MIEHE deformation is no longer supported in code_aster 2024 with mfront codes. I wonder if there is another alternative to that in order to use a similar formulation (F=Fe*Fp) in v2024, please. The most favorable situation is the existence of an alternative that can still be used with mfront. But if this option is not available, can this formulation still be used in UMAT?
Thank you a lot for your time and support.
Best regards
Ava
