Hi everyone.
Could someone share some tips on how to reduce the size of the files generated when doing an analysis in salome_meca?
A simple linear elastic example of a cantilever beam I did using salome_meca on Windows occupies 130 MB, which is way more than same analysis using abaqus or prepomax.
It seems to be mostly in glob.1 file.
Maybe I'm selecting too much data for the results? Or maybe I should delete this file after the run finishes? What would be the best practices for this?
I'm learning to use salome_meca, little by little, following tutorials in youtube. These tutorials normally do not discuss the aspect of memory management.
Below I leave some information:
.hdf file: 790 KB
.rmed file: 2236 KB
RunCase folder files:
_ExportedFromSalomeObject_0_1_2_5.med --> 508 KB
RunCase/Result-Stage_1/base-stage1/ folder files:
glob.1 --> 127 MB
Anyway, thanks in advance.
