sameer21101970 wrote:
It is converging, do below.
Make Sphere (ball)Mesh Fine.
Reduce Time Step to 100
Sammer, how small was the ball mesh size in your setting?
I ended up using this setting:
[ball = 0.1; substrate = 2.5] & number of time steps = 100
But even with this master-to-slave mesh size ratio in 1.5, it still gave out convergence issue.
I have attached the log of this latest trial FYI.
In which there was a multiple occasion of occurred:
! Les déformations deviennent trop grandes : !
! => GROT_GDEP sous COMPORTEMENT n'est plus valide. !
! Pour un calcul en !
! grandes déformations !
! il faut utiliser GDEF_LOG ou SIMO_MIEHE. !
! Pour un calcul hyper-élastique, utiliser ELAS_HYPER. !
! This is a warning. If you do not understand the meaning of this !
! warning, you can obtain unexpected results! !
Is it something related to the convergence issue?
I am unable to test further shrinking the ball mesh size for the time being, as somehow Salome-Meca is giving out fatal error whenever loading up the mesh of all previous case files:
Any suggestions other than re-installing Salome-Meca?
mib wrote:
maybe this
code-aster.org/doc/default/en/man_u/u2/u2.04.04.pdf (copy and paste in your browser)
from 2.2.3 Case general
to 2.2.7 Quality of the grid
Thanks for the info Mib.
So I suppose this is a hard-coded limitation of CA?
Then this is not a good news for me, because the physics in my case study includes deformation mechanism & local strain hardening effect at the ball / substrate under the same length order.
Are you suggesting that I should look for other simulation tools instead?
stderr_command_salome.log, 157921kb
