Hi
I learned Aster when you first had to compile it with Intel compiler and MKL around 2003/2004.
The whole learning was really hard but i had the time.
Very useful learning experience and an opportunity to compare with others softwares (Abaqus)
I lost touch around 2016.
Coming back to it recently to assess a thermal problem (1st Aster, then i will see if i need to move to Syrthes):
a. Coudn't do a Ubuntu install with the Singularity stuff and didn't want to lose too much time if others solutions would work (hence: Windows & Salome-for-Windows 2021). Salome-Meca direct install also wouldn't work on Ubuntu.
b. Had issue to just download Salome stand-alone: website link to working to get the file after filling up all infos...
So, yes, starting/restarting is difficult but maybe easily fixable?
Yet, if/when Salome-Meca is working (Windows today sadly for me, but hopefull it will change), i got my simulation set-up and working in much less time that i would have thought it would take.
The integration is really an improvement.
And i can see that User Meetings started again, with sharing of the presentations...
Hopefully it will follow a good trajectory/path and this discussion might help getting attention on some of the issues
ps: now reading AsterO'dactyle's comments: i am one of those individuals, using the strength of an industrial code @no cost, which has served me well. I try to help whenever i can, but as mentioned, some questions reflect how complex simulation can be.
Personnaly, Aster & Saturne helped me pushing topics i could never push without demonstrating by myself (with those tools) a few points conceptually. Then things got started. So, thank to the community for that. But no nice presentation to share! I could relate some experience if that helps
ps2: @Corra have you checked the Pronet code-aster.org/V2/spip.php?rubrique62 page regarding support?
