I post it directly:
Please explain AFFE_CHAR_MECA from Code Aster.
ChatGPT:
In Code_Aster, AFFE_CHAR_MECA is a command that applies mechanical loads or boundary conditions to a model. The command is central to defining loads such as forces, pressures, moments, or constraints like fixed supports on a mesh in a mechanical analysis.
Here's a breakdown of how AFFE_CHAR_MECA works and its key features:
- Basic Structure
The AFFE_CHAR_MECA command is used within the STAT_NON_LINE, MECA_STATIQUE, DYNA_VIBRA, or other mechanical analysis commands. The general syntax looks like this:
python
AFFE_CHAR_MECA(
MODELE = model,
[other load options],
MODELE: This is the mechanical model on which the loads or boundary conditions will be applied. It is defined by a previous AFFE_MODELE command.
The load or boundary conditions themselves can be specified with various options and keywords, depending on what type of load you're applying.
- Common Load Types
Here are some commonly used options within AFFE_CHAR_MECA:
FORCE_NODALE: Defines nodal forces on specific nodes.
Example:
python
FORCE_NODALE = (
_F(
NOEUD = 'N1',
FX = 1000.0,
FY = 0.0,
FZ = 0.0,
PRES_REP: Defines a surface pressure applied to a group of elements.
Example:
python
PRES_REP = (
_F(
GROUP_MA = 'SurfaceGroup',
PRES = 5.0,
PRESSION: Defines pressure on specific elements or element groups.
Example:
python
PRESSION = (
_F(
GROUP_MA = 'ElementGroup',
VAL = 5000.0,
LIAISON_ENCASTRE: A fixed boundary condition (like clamping) that prevents any movement.
Example:
python
LIAISON_ENCASTRE = (
_F(
GROUP_NO = 'FixNodes',
DDL_IMPO: Imposes specific displacements or rotations on nodes or node groups. It allows you to fix or impose specific degrees of freedom (DOF).
Example:
python
DDL_IMPO = (
_F(
DX = 0.0,
DY = 0.0,
DZ = 0.0,
- More Complex Loads
In addition to these simpler loads, AFFE_CHAR_MECA also supports more complex loading conditions, including:
GRAVITY: Application of gravitational force by specifying the acceleration vector (usually [0, 0, -9.81] in the Z direction).
python
GRAVITY = _F(
GRAVITE = (0, 0, -9.81),
THERM_EXCIT: Thermal excitation, used to apply thermal loads that may result in mechanical deformation due to thermal expansion.
MOMENT: Application of moments (torques) around nodes or node groups.
- Practical Example
Suppose you are modeling a cantilever beam with a fixed support at one end and a nodal force applied at the free end. Here’s an example of how you might apply these boundary conditions and loads:
python
AFFE_CHAR_MECA(
MODELE = model,
# Fix the nodes at one end of the beam
_F(GROUP_NO = 'FixedNodes'),
# Apply a nodal force at the free end
FORCE_NODALE = (
_F(
NOEUD = 'FreeNode',
FX = 0.0,
FY = -1000.0, # Force of 1000 N in the negative Y direction
FZ = 0.0,
- Advanced Use
You can combine different types of loads and boundary conditions within a single AFFE_CHAR_MECA command. This makes it very flexible and adaptable to different mechanical scenarios.
For instance, you could apply both surface pressure and gravitational loading simultaneously like this:
python
AFFE_CHAR_MECA(
MODELE = model,
PRES_REP = (
_F(
GROUP_MA = 'LoadedSurface',
PRES = 100.0, # Pressure in Pascals
GRAVITY = _F(
GRAVITE = (0.0, 0.0, -9.81), # Gravity in the negative Z direction
- Chuck Norris Version
When Chuck Norris runs AFFE_CHAR_MECA, he doesn't apply the loads; the structure imposes them on itself out of respect.
In short, AFFE_CHAR_MECA is one of the workhorse commands in Code_Aster for applying mechanical loads and boundary conditions. Its flexibility allows for simple to highly complex scenarios, making it essential for any mechanical simulation in Code_Aster.
